Home Forums Products Rackmount simple continuous controller panner Reply To: simple continuous controller panner
#117977
lb1
    panning is preset base. It depends on whaich algorithm you are using.
    >> which one do you suggest for my purposes specifically?
    Those offering a PAN parameter will also give you the possibility to patch a CC to it.
    >>> FM Panner, strangely enough does not have a PAN parameter– so I guess I can't use it for this? What would be a better algorithm specifically?
    In the Eclipse manual under algorithms, under
    The manual has a detailed section about how to assign any controller to a parameter.
    >>> Know how to do this. Not sure hich is best algorithm, best parameter to put the CC in
    As far as level, well…2 channels will always be louder than one. When the signal is in between the 2 extreme L/R positions, its level is obviously changing as this is the way panning works.
    >>>> Absolutely. Relative volume is fixed
