Home › Forums › Products › Rackmount › Input LEDs › Reply To: Input LEDs
#118104
I am using Version 3.5 of the OS.
I will go into levels and setup the IN GAIN to see if this helps. I can use Serial or Parallel on the loop. I am currently using Parallel.
I have only input 1 connected and have it set on IN MODE to MONO 1
If the above does not work I will reivew the technote to make sure this is not an issue.
Thanks for your quick response.
