Home › Forums › Products › Rackmount › Problem with midi mapping › Reply To: Problem with midi mapping
Hi, thanks a lot for replying Nick. I just wanted to select the preset 200-300 range in the eclipse. My controller only sends 0-128(yes has option to select midi from 00 or 01 style midi devices)…
So I go to eclipse setup, maps, I see that map #1 is selected and leave that. There you'll see:
( map #) (progchg#) (preset#) <reset map>
Map 1 is default I put the preset # parameter on 0-200)The (pgmchg# parameter I don't mess with. It will say 0-200 after I change the (preset#) parameter like I said above.
Am I correct that this will offset program number by 200. For example I send program change #02 it will select preset 202?
Also, when putting in a number for the (progchg#) , it will not let you use the keypad to put in the values(it just goes blank if you try to use the keypad). The (preset#) parameter WILL let you use the keypad to enter values..strange there.
A few times, thinking I would reset the map after I alter it didn't work for me…the reset would not always work after I changed the progchg# and preset# parameters.
Thanks again for the reply Nick,
Sincerely,
Show More...John
