Home Forums Products Rackmount Sounds really wierd Reply To: Sounds really wierd
#118213
Itaiargaman
     Thanks Italo,
    The presets are all Shifters Ultra between 5610-5622
    I tried to load a few different sources (mono Female Vocal,Stereo Fem Voc,Mono and stereo Male Voc)
    input level- in analog I can see 2 leds(if i change the settings on my RME cards to Hi output Gain I can see 4-6 Leds) but when i changing to digital i can see the LED's at -5dB(almost full).
    "what are the "fixes" you added in the Patch Editor?"
    well,just enter to the patch editor then press on modify then press the select button,
    and then a "pop up" window sais "modifying" and "loading new patch",
    it solved the problem but i have to do it every time  i want to launch the preset,
    by the why, when doing this "fixing" thing the inputs leds are stuck.(No reaction till I go to "setup">Meter< and modify the input meter again….
    please let me know if you need more details,
    Thanks
    Itai
