Home › Forums › Products › Rackmount › Setting up Routing with the H8000FW › Reply To: Setting up Routing with the H8000FW
#118218
 That helped a lot! Indeed, I got my routing problems sorted out using routing #27 (plus a few tweaks, of course). Unfortunately, a new problem seems to have emerged. I'm having dropout problems over fireweire, even with the buffer size set at its highest level.I don't know if that's the issue though. At any rate, during the dropouts the meters on the analog inputs still light up, but the sample rate indicator (I'm at 44.1khz) flashes off and switches to "ext" for a moment. I don't know what might be causing this. Any suggestions?
