Home Forums Products Rackmount Reversing Dsp effects? Reply To: Reversing Dsp effects?
#118420
    Not quite sure what you mean by "reversing the effects".
    Assuming you mean changing the order of series effects (e.g. putting the reverb before the shift rather than after it) the answer is yes.
    You can change the routing (the internal audio connections) to change this and many other aspects of the effects.
