Reversing Dsp effects?
Home Forums Products Rackmount Reversing Dsp effects?
Viewing 3 reply threads
    • #106136
      akjl4
        Hi. just wondering if the H8000 allows for the reversal of the effect thats are loaded onto processors A/B? Sometimes I wonder if I might like the sound better if reversed.
        I realize some presets use both processors and can only be loaded on A.
        Thanks,
        Alvin
      • #118420
          Not quite sure what you mean by "reversing the effects".
          Assuming you mean changing the order of series effects (e.g. putting the reverb before the shift rather than after it) the answer is yes.
          You can change the routing (the internal audio connections) to change this and many other aspects of the effects.
        • #118423
          akjl4
            lets say I have a delay on processor A and a reverb on processor B, well now I would like to put the reverb on A and the Delay on B to see if I like that better. Just curious if there is a fast way yo do this?
            Thanks,
            Alvin
          • #129561
             -reload reverb on A and delay on B
            or
            -if the two dsps are in series, A>B, change routing to B>A.
            First solution is definitely FAST!
