Home Forums Products Rackmount a little advice before v4 is released please Reply To: a little advice before v4 is released please
#118565
     When you install an update you are STRONGLY recommended to perform a clear setup. This is because old setup parameters may not be compatible with the new version. For the same reason, you should NOT attempt to load a saved setup from a previous version. Unfortunately, the best way is to manually reconfigure the unit.
    This does NOT apply to saved (user) presets – these are safe to use with later versions.
