Home Forums Products Rackmount shifting formants Reply To: shifting formants
#118692
formants
    In the
    software "Melodyne" and the "elastique" you have the option to shift
    pitch and to shift formans. Formants shifting in a – direction makes
    the sound more muffled if you add more formants the sound becomes more
    treble high quality. I do not how to explane it better. I totally
    understand your mentioned aspect:
    different pitches so that the sound remains "loyal" to its character over the shift
    But for me the nice thing was to be able to play with the density of the sound.
    So if Eventide has calculation (with the Ultrashifter)I was hoping that
    there is a way to have the possibility to calculate those formants
    fluently….
    http://images.google.de/imgres?imgurl=http://www.musicmarketing.ca/products/images/melodyne_plugin2.jpg&imgrefurl=http://www.musicmarketing.ca/products/melodyne_plugin.asp&usg=__lfVox09K1AqxOYmMo9mz0zban2w=&h=362&w=600&sz=30&hl=de&start=11&um=1&tbnid=xo8H8TkDq3RSCM:&tbnh=81&tbnw=135&prev=/images%3Fq%3Dmelodyne%2Bl%2Bformant%26hl%3Dde%26client%3Dfirefox-a%26rls%3Dorg.mozilla:de:official%26sa%3DG%26um%3D1
    Thanks for trying to help
    Am Fri, 5 Jun 2009 12:40:00 -0400
     schreib IDeangelis <bounce-IDeangelis@eventide.com>:
    Hello
    it sounds a bit unclear to me what exactly you need to do.
    Normally you don't pitch shift formants; they happen to be the peculiar
    physical aspects a phonetic media overimposes on the sound it
    generates. When you pitch shift such sound, the formant_accurate pitch
    shifter should calculate the correct formant at different pitches so
    that the sound remains "loyal" to its character over the shift range,
    avoiding chipmunks artifacts.
    Could you explain what exactly is t he task you are looking into?
    thanks
    I —
    View this message online at: http://forum.eventide.com/cs/forums/p/5504/23376.aspx#23376
