Home › Forums › Products › Rackmount › Bulk copy to CF card › Reply To: Bulk copy to CF card
#118710
What is happening is that you when you select the "Dest Frm" soft key, you are most likely not changing the information to the number location that complies with the compact flash card.
When you want to save presets to the compact flash card, these have been provided in the Eclipse software from numbers 500-999. These numbers are also only accessible once an CF is inserted into the Eclipse. Remove the CF and the program numbers will stop at the last factory preset of 499.
So if this is the first time you are backing up to the compact flash card, you will most likely want to begin at #500. Depending on the number of presets you'll have, the system will number the amount accordingly. This info may also be found in the manual under "Bulk copying programs".
Hope this helps.
