Home Forums Products Rackmount Guitar tone changes with the eclipse Reply To: Guitar tone changes with the eclipse
#118784
simeon
    change the global mix to 100% and make sure the fx loop on the amp is set to 100% wet also and see if it's any better. sounds like you're hearing a mix of the dry signal going around the loop and the dry signal passing through the eclipse
