Home › Forums › Products › Rackmount › Using fw for effects and 4 analog out as da converters › Reply To: Using fw for effects and 4 analog out as da converters
#118829
Hi Rolando
unfortunately you don't describe how many H8000 I/Os you are using and on which routing; I can't be very specific on my reply. But one thing may enlighten you. The H8000FW has several inputs (FW/Analog/AES/AES on breakout cable/S-Pdif/ADAT) but you should always remember that only 8 inputs are available at the same time, to feed the DSPs. The most important aspect of I/O setup is configuring the MAIN Inputs & the MAIN outputs…and they are 8.
I suggest you familiarize more w/the user manual as the high versatility of this unit requires that, to fully use its potential.
all the best
I
