Home › Forums › Products › Rackmount › H8000fw as a soundcard. › Reply To: H8000fw as a soundcard.
#118855
Sonic Nomad
    Sorry, but this is not true.
    Pro Tools, both the LE and HD only recognize their own interfaces and drivers.
    The only way to get signal from the H8000FW into Pro Tools is via the ADAT or AES digital connections.
    So you would need to get one of the bigger Pro Tools Le interfaces. Preferably the 003 or 003 Rack so that you can use the ADAT I/O and sync via the wordclock connectors.
    Another option is a M-Audio interface and the Pro Tools M-Powered versions.
    You need to also consider that when using the above configurations that you arre limited to 48K sampling rates and won't be able to go up to 96k.
