Home Forums Products Rackmount Strange behaviours Reply To: Strange behaviours
#118873
Ok, now that I got the time I can give you the complete list where I heard the "cracks":
158 AutoCorrect
159 DualWammy
162 St Shifter
163 DiatonicShift2 (only minor pops, here)
164 Multishift2
165 DualDiatonic
166 DualMultishift
167 DiatonicShift4 (minor pops)
168 MultiShift4
184 Mshift+Reverb8
185 Dshift+Reverb
186 Stshift+Reverb
232 Bob's Delay (plus cracks, also continuos Hummmmm, here!)
245 ShiftedVerb1
246 ShiftedVerb2
247 ShiftedClusters
279 Diat+3rd+5th
280 Diat+5th+7th
281 Diat+4th+6th
282 Diat+5th+Oct
283 Diat-4th+5th
284 Diat- Oct+5th
285 Diat-Oct+Oct
286 Diat+5th+10th
296 Micropitchschift
300 Thick -500's
301 Thick 1200's
302 Thick -1200's
308 Sleeplechese2
339 Rainbow Drops
344 SpacedSpaces
449 Flangedown
355 BrillianceLoop
359 Quintillizer
363 OctaFuzz
389 Ring-A-Verb
395 Artifacts
404 DrnkMusik
406 EvilHiLowShift
447 EtherHarp
449 GentleGiant
465 Eclipse Rocks
477 Watery Chorus
479 Magic Air
480 Voice Douber
488 E.Z. Chorus
491 Mondo Chorus
493 Ballerina
804 Bulge Tales
805 FlangDlyThick
807 Verb Swims!
811 GTR Rig #1
834 Pitched Dlys
840 Finally_the5th
901 TF 1:2 Multitap (strange sandy roumors)
910 TF 6:1 FiltPongs (strange creepy hiss)
In a few words, seems that the whole Pitchshift stuff is KO.
The tests were made both with the whole rig connected (guitar, valve preamp, line mixer, Eclipse, power amp and speaker) and with only Eclipse with no imput, going direcly into the power amp and the speker. I use only analog stereo inputs and outputs, no digital.
Display problem is the same in the v4.0. Often, after a few repower, the bottom line (the area where direc key compare) doesn't display leters correctly, but some leds that shoul be on are off and some one should be off is on, in a casual order and with incostant grade of number and "entropy". It doesn't happen always, only sometimes, expecially after editing operations.
Card I tried an old 32 MB Hamlet and a new 2 GB SanDisk Ultra II (15 MB/s). Both were formatted FAT using a Digitech JamMan as card reader and deleting the directory he creates for itself. Both were used succesfully to upgrade the firmware.
Plus, I don't know if it's a v4 bug, but loading
437 GravelyThroat439;  438 Logan's Box; 439 Soudwave; 440 Vocoder13  the system crashes, keeping blinking the bypass, parameter, Khz and bypass ledd consequentially.
