Reply To: Delay Calculations
Home Forums Products Rackmount Delay Calculations Reply To: Delay Calculations
#118912
IDeangelis
HI Yannis
this is stuff created very long time ago.
We included examples in the presets library for programming use (and studying purposes).
Check 7015 Tempo Dly_Lfo Jig
Basically the MIDI Clock module has to be set with inner values you will see if you open it in Vsig (you could also check its module help description). This module works for Tap Tempo hardware controllers too if set that way; no MIDI is needed. The value it sends out is then multiplied by the control table values to provide the rhythmic figures needed. Probably just easier to use the jig as it is…. it works!
There is no newer help file version than 2.0 at the moment. Maybe Nick can add some info?
best
I
cheers
I
