Reply To: crackle and glitches on engine a
Home Forums Products Rackmount crackle and glitches on engine a Reply To: crackle and glitches on engine a
#118963
IDeangelis
Hi Lars
I just tried to reproduce your reported problem…but everything sounds ok here, on both A and B.
I'm using internal routing #15 Analog Dual Stereo and get no cracks on the verb tail loaded in DSP A, either while playing audio or stopping it thru it.
I suggest you verify your signal chain, cabling,gain, anything that you use in your setup.
all the best
I
