Home Forums Products Rackmount no Send in algorithm FuzzWaWammyPre (149)? Reply To: no Send in algorithm FuzzWaWammyPre (149)?
#119040
Thanks for the answer!
Yes, it does work IF I set the EFFECT (in Parameters-> Pedal) to volume.
Problem is: I want to use the wammy transposition fixed to -1200 for instance. To achieve that, I have to set the EFFECT to wammy, otherwise, I don't get any transposition, right?
But when I set the EFFECT to wammy, then I can't control the "volume" anymore, right?
Actually, as far as I understand, in this algorithm, there is a choice (eXclusive OR) between the volume, the wammy, and the wawa. Or what am I missing there?
Thanks for your help!
J-F
