Home › Forums › Products › Rackmount › 1) levels for Guitar Amp FX Loop and 2) How do you get that effect? › Reply To: 1) levels for Guitar Amp FX Loop and 2) How do you get that effect?
September 21, 2009 at 6:56 am
#119065
Hi Zap
the Eclipse is very clean when it comes to sound coloration. If using bypass set to RELAY bypass, the signal will not go thru DSPs when bypass is engaged, provided you use XLs I/O, which is what you'll want to use with a +4dB FX loop.
Input levels should be monitored on the front panel LEDs. Lighting the yellow area is the good point. There is an analog input gain where you could boost the input signal if necessary.
Sorry…can't hear any filter sweeping other than, MAYBE, something between the 5th and 8th second. Is that it?
best
I
