Reply To: Eclipse V4.0 Full Release available
Home Forums Products Rackmount Eclipse V4.0 Full Release available Reply To: Eclipse V4.0 Full Release available
#119153
maxmartinelli
Thank you for the new OS!
I have installed the v4.0 some days ago and until now I had zero problem…
I would ask some new capabilities for the next release: It would be possible to add a parallel dry signal on each FX block? I'm using the Wet/Dry ratio at 100% and sometimes I need the dry signal parallel to the wet…until now I use the Thru_Series block, but in this way I cannot use a second FX block. If I set the FX mix at 50%, when I bypass the effects I have a big difference in volume…so I would prefer to have a parallel dry signal for each block at the same level of the input.
Thank you very much,
Max
