Home Forums Products Rackmount Miciclock module upgrade? Reply To: Miciclock module upgrade?
#119203
Thanks for the quick reply Nick!
An apology. My problem wasn't clear and to top it off, I must have made some mistake when using the H8000 as a clock master. That part works as a charm now. Both Eclipse and computer really are in sync when doing something like 1/16 note delay/loop on eclipse with S/H filters also modulating on 1/16 note from H8000 and drum loop from PC w/ reaktor. I just can't decrease the tempo too quickly from the H8000 tap tempo or the Eclipse doesn't follow but that's ok.
I'm still having problems with the H8000 slaving both from my Eclipse and Gordius Little Giant MIDI foot  controller running it's built in tap tempo midi clock though. This is prefered so I don't have to run MIDI Clock back from the H8000 to little giant and merge with the the rest of the data. I'll get back with a detailed description later though because now I'm off to a weekend of jamming.
PS I know having both the Eclipse and H8000 is overkill but I'm planning to let go of the Eclipse once I programmed the H8000 good. But the rotary speaker still sounds better than the presets I found in the H8000 so far.
