Reply To: Tap Tempo using latching footswitch connected to pedal 1 jack
Home Forums Products Rackmount Tap Tempo using latching footswitch connected to pedal 1 jack Reply To: Tap Tempo using latching footswitch connected to pedal 1 jack
#119240
eugenelhymn
So any unlatching pedal via 1/4" to either pedal 1 or 2, and designate tempo source in the setup menu?  Also, I'm currently running 3.51.  All sounds good here?
Is the footswitch method more accurate than MIDI CC method?
