Reply To: problem: ADAT connection to H8000FW
Home Forums Products Rackmount problem: ADAT connection to H8000FW Reply To: problem: ADAT connection to H8000FW
#119271
Can you plug the ADAT from the TC into something else to see if it is sending anything ?
Using the factory routing you mention should make the ADAT show up on the input meters.
