October 20, 2009 at 3:40 pm
        #119294
No1) Did you get it prior to V4.0 ?
I did have the same issue with v3.51 previously.
2) Do you get it with "Thru Series" ?
Yes…I do.
3) Do you get it in DSP bypass ?
No.
4) Do you get it in relay bypass ?
Not sure what you mean here…
This may be my problem. I only have about one or two green lights here in the two setups I use(direct or effects loop) Any suggestions on how to get the best possible signal here? thanks guy you are the best. randy
