Home Forums Products Rackmount h8000FW does not work with mac Reply To: h8000FW does not work with mac
#119316
Hi passion presents
Eventide provides VSIGFILE Algorithm Editor for Windows PC only. This tool is required ONLY if you intend to create algorithms. It's not needed to operate/control the H8000.
Third party provides VsigX for Mac. We don't support this version, so any request for support/advice should be directed to them.
At this time the options to program algorithms on a Mac are:
-using VsigX
-using Bootcamp/VMware Fusion/other virtualization software to run Windows on a Mac.
As for the serial connection, the Keyspan USB to Serial adapter should be connected to the USB port of a Mac or PC and use a serial cable from the serial port of the Keyspan to the one on the H8000. I have several cables and have no problem doing this on several Macs and PCs.
I have no problems in serial communication with the unit on ANY computer, running 10.4/10.5/Win XP.
What is exactly the problem you are having?
warm regards
I
