Home Forums Products Rackmount Have all three Factors, not sure what to move up to Reply To: Have all three Factors, not sure what to move up to
#119364
rmaxwell
    Eclipse is Eventide's greatest hits effects box. Tuned for live performance, Eclipse has superfast program load time and takes up only one rack space.  It has two processing engines so that you can run two effects at one time, either in serial (one effect feeding another) or parallel (you can seamlessly crossfade between the two).  Eclipse V4 (released recently) now includes all the effects from TimeFactor and ModFactor, improved pitch tracking taken from PitchFactor.  Eclipse V4 now has over 500 presets, and supports compact flash for storing presets.  True, Eclipse does not do VSIG, but VSIG has a rather steep learning curve.
    I would be happy to discuss this with you, if you like.  Shoot me an email with your number and I'll give you a call.  rmaxwell at eventide.com.
    Hope this helps.
