Home › Forums › Products › Rackmount › eclipse as tc2290 › Reply To: eclipse as tc2290
#119507
Right folder!
Thanks
Yes
My reply from the Harmonizer folder….
Hi kitsch
you can't get an exact 2290 copy on the eclipse as you have on
Orville/H76-8000 models. Infact these units allow dry signal dynamic
panning as in the TC unit.
You could try using any modulated delay algorithm and patch its
delay mod rate, pan and level to FOLLOWER #1. This may lead to a
similar rsult, even though not so accurate as on the bigger brothers.
Try #106 Chorusdelays and tweak a single delay; cut the other 3 delays levels down to -100dB.
Vintage delays is not well suited as it has a single delay level and an IMAGE parameter for both delays panning image.
best
I
