Home Forums Products Rackmount w/d/w or all wet virtual rack Reply To: w/d/w or all wet virtual rack
#119728
You don't need VSIG for W/D/W.  You need a seperate wet signal path in amp rig.  It is really just a parallel rig.  Mono dry tone to a 212 center cab and 2 112s for wet.  Set the Eventides to 100% wet.  Grab a tap from your amps send or some kind of line out and feed the Eventides… send their outs to a mixer and send the mixer out to a stereo power amp and then the outs from the amp to the L and R wet cabs.  All done.  🙂
