Home Forums Products Rackmount Meter and Tuner in Effects Loop Reply To: Meter and Tuner in Effects Loop
#119758
Hi Rich
we need to know the following:
-Eclipse is running in an FX loop. Which kind of level is the FX loop designed for (+4dB/-20dB)?
-which type of cables are you using and whick connectors on Eclipse?
-how IN GAIN is set, under LEVELS?
I believe you are referring to the input LEVELS leds with the word "meters"?
best
I
