Home › Forums › Products › Rackmount › Meter and Tuner in Effects Loop › Reply To: Meter and Tuner in Effects Loop
January 11, 2010 at 12:09 pm
#119759
I am using XLR(Eclipse) to 1/4 inch unbalanced for input and output. In and out gain set at 0. Mstr out at 15.
I am using a Carvin Legacy and here is the only info I was able to get from the manual, but I will call Carvin to get the answer unless you already know based on the amp type. Yes, I am referring to the levels LEDs.
It’s possible to have a slight gain reduction
of several dB with some effects units. However, the amp has plenty of gain to overcome any
loss.
Thanks very much.
