Home › Forums › Products › Rackmount › Ext. midi controller to adjust effect parameters on Eclipse › Reply To: Ext. midi controller to adjust effect parameters on Eclipse
January 20, 2010 at 1:04 pm
#119818
Hi Jan
I have moved your post in the Eclipse folder.
Just highlight the parameter you want to MIDI control, press & hold its softkey and a new menu will pop up on the display. Press <MODULATE> to access the pstching area. Choose the EXTERNAL you have already setup and work thru the min/max scale of how you want the parameter to be controlled by the MIDI CC. That's it. You need to re_store the preset or the patch will get lost in space.
best
I
