Home Forums Products Rackmount crackle and glitches on engine a Reply To: crackle and glitches on engine a
#119847
    There is a specific hardware problem that can cause clicks with certain reverb presets on DSP A ONLY. It is more likely to apply to H8000's than Orvilles.
    If you think you have this, you should contact your dealer (if they are good at repairs) or Eventide (support@eventide.com). There is no easy answer – fixing it requires changing surface-mount chips.
