Home Forums Products Rackmount DSP7000 Update Question Reply To: DSP7000 Update Question
#119863
glennfin:
If I need to update the OS to the latest 3.0, can this be done the same way the Eclipse is updated? using a memory card?.
Not really, because the DSP7000 doesn't support Compact Flash. As a result, the serial approach is the only one you can use.
