Home › Forums › Products › Rackmount › Using Eclipse with AES : poor signal › Reply To: Using Eclipse with AES : poor signal
February 8, 2010 at 4:37 pm
#119960
hello nickrose
thanks for your reply
i'm using a
digisnake db25 cable 110ohm compliant so i can't test to connect AES in
to out. But if i change the routing matrix table in my alphalink to input AES > output AES is'nt the same thing that you suggest ? (it would be better than buy a new cable)
Eclipse
is synced to worldclock and i'm on XLR in Digin Setup.
I also
tried to change routing matrix on Xlogic
