Home Forums Products Rackmount Digital Connections-wires fall out! Reply To: Digital Connections-wires fall out!
#119992
t_tangent
    Re ADAT connections falling out I have the same problems, but that is due the edge of the ADAT connection on the cable being slightly too wide so it gets in the way and the ADAT plug doesnt quite clip into place. I have made do by just getting some velcro cable ties and attaching the cables so some others and that holds them in place so long as the unit is not moved. There are other ADAT cables available that have a thinner actual connector head on them which might work better for you and I will need to get some of those soon too, but for now it works ok for me ðŸ™‚
    Not sure about the other issues you are having as I am PC based, but hope you get it sorted
    Cheers
