Home › Forums › Products › Rackmount › Midi and Ground Control Pro › Reply To: Midi and Ground Control Pro
        February 19, 2010 at 5:40 pm
        #120030
You should pretty much always see the BUSY indicator flash when you receive MIDI.
This suggests that the Eclipse is not in fact receiving MIDI. First check the GC settings (can't help you there) then try a different cable. If still no good, try and connect the GC to some other equipment to see if you can make it work.
