Home › Forums › Products › Rackmount › logic pro firewire latency – how do you compensate? › Reply To: logic pro firewire latency – how do you compensate?
February 27, 2010 at 6:13 am
#120052
Hi
latency can be compensated but not get completely rid of.
You may want to check the User Manual section "Setting The Sample Rate and Buffer Size for the System", on page 158.
If true zero latency is what you are after, either your DAW has software for the purpose or you may want to consider using AES-EBU or ADAT connections.
all the best
I
