Reply To: logic pro firewire latency – how do you compensate?
Home Forums Products Rackmount logic pro firewire latency – how do you compensate? Reply To: logic pro firewire latency – how do you compensate?
#120053
xnix
I still don't really know what to do.
I am running the H8000fw as an aggregate device in logic. The latency is not an issue with my sound card and logic, but when i run a track through the h8000fw via firewire the latency between the effected sound and the original track is huge which is completely unusable.
What do I adjust to sync this up? The buffer?
Am i using the unit wrong? How do people successfully use the firewire routing?
