Home › Forums › Products › Rackmount › UltraShifter Autocorrect tweaks? › Reply To: UltraShifter Autocorrect tweaks?
March 2, 2010 at 11:54 pm
#120081
philjochum:
Also, I read somewhere about a glitch in the UltraShifter patches
Load the preset, go into the Patch Editor, insert a small module, then delete it and exit the Patch Editor. Save the preset.
This bug is fixed in the forthcoming V5.5.
philjochum:
Finally, does anyone know if there's enough horsepower to process more than one UltraShifter stream
Ultrashifter is pretty demanding. If all you need is autocorrect you can probably get by with a DIATONIC. You can usually get a number of these per dsp.
