Home › Forums › Products › Rackmount › maximum efx per program › Reply To: maximum efx per program
#120169
    The Eclipse is finite. It will run one effect, which may consist of FXA and optionally FXB. In addition there is a "Modulation Block" which may be thought of as FXC, which allows many modulation options on the main effect.
    Effects which are only FXA can be crossfaded with each other, allowing a "spillover" on preset change.
