Home Forums Products Rackmount Flash Card/Tempo Sync/Levels Query Reply To: Flash Card/Tempo Sync/Levels Query
#120230
    a) Could be the card or the adaptor. Contact support@eventide.com to get them replaced.
    b) Unclear how the H8000 could know the DAW's tempo apart from MIDIclock. Mind reading ? Note that not all delays are tempo-controlled – depends on the preset.
    c) Not sure what your levels problem is – normally you set everything to 0 dB and the outputs are about the same levels as the inputs. You don't say what your routings, sources and destinations are, so it's hard to suggest anything. Start by getting a good level on the meters, then adjust the outputs for the desired level.
    d) Not all ADAT cables fit well into the TosLink connectors. Some are better than others – there have been a number of forum post on this topic.
