Home › Forums › Products › Rackmount › Severe Update Problem to 4.01 on Compact Flash Card. Mangled the entire OS. › Reply To: Severe Update Problem to 4.01 on Compact Flash Card. Mangled the entire OS.
May 3, 2010 at 6:28 am
#120373
Hi Zap
hard to say why you got this problem. It may be a corrupted download, a non compatible compac flash card…..
Which OS version was the unit running on?
Have you already used that same card for previous OS updates?
You can try the following:
-reinstall the previous version 3.51, using a card or a serial cable
-check your bootloader version
both procedures and files are available here:
please let us know
best
I
