Home Forums Products Rackmount Syncing tap tempo with Eclipse, Pitchfactor and PCM92 Reply To: Syncing tap tempo with Eclipse, Pitchfactor and PCM92
#120432
Aro
    OK, I tried this out but it doesn't work for me – here's why:
    I need to be able to have all the devices react to midi cc's (control change) sent by my midi controller – and in addition pitchfactor should also respond to sent midi pc (program change) commands.
    I can get the PCM92 receive tempo information from Eclipse clock sent from its Midi Out port, but I couldn't get Eclipse to send to tempo information thru it's Thru port. Also I couldn't get Eclipse's Midi Out port to send the mifi "thru" data sent from my midi controller. If this is possible. please let me know.
    So if  I tap the tempo to Eclipse using cc's and my midi controller, can the Eclipse send this tempo information to PCM92 from the midi clock (BNC) output?
    Thanks
