Home Forums Products Rackmount Help with initial set up for H8000FW Reply To: Help with initial set up for H8000FW
#120584
    I regret that you really do have to follow the User Manual to set these things up – this is complex stuff, and you can't just busk it.  Be sure to follow the instructions regarding setting up the Core Audio connection first, and only when this is fully working as described in the Manual should you move on to Logic.
    If you still have problems, contact support@eventide.com.
