Home › Forums › Products › Rackmount › Mute / Bypass › Reply To: Mute / Bypass
July 16, 2010 at 1:27 am
#120588
But for reasons that aren't clear to me, when you switch bypass to "mute all" in the setup menu, it doesn't flow through to program 100. Program 100 remains a bypass with the dry signal passing thru the eclipse. You still have to push the bypass button to stop the signal from passing thru the Eclipse.
