Home Forums Products Rackmount Weird problem Reply To: Weird problem
#120591
J20056
    Well, the problem happens even if I store program #876 to the Internal, not just the Card. It also happens with program #877, but otherwise works fine with say #824 or lower.
    I only need to do this so I can call MIDI program changes as MIDI can't do numbers >127.
    If I return the unit to factory defaults, is it going to mess up my overall config, including usergroups, as that's what I use to send MIDI program changes?
