Home Forums Products Rackmount H8000fw Out 3 and 4 NON FUNCTIONNING Reply To: H8000fw Out 3 and 4 NON FUNCTIONNING
#120737
    Two things to try:
    1) are IN 3/4 and OUT 3/4 connected when the unit is switched off ?
    2) Do you get audio if you unplug the cables from IN 3/4 and OUT 3/4 and connect them to each other ?
    If the answer to either of these is no, the problem is probably at your end. Otherwise, contact support@eventide.com and refer them to this post.
