Home › Forums › Products › Rackmount › No output using ADAT? › Reply To: No output using ADAT?
#120764
Hi Nick, So i get a signal when going from adat out to adat in on the H8000FW.
Just trying to send the adat output to my sound card and/or my stereo reciever.
Using routing# 12 ADAT A-B..
I would like to use my Maton Acoustic pluged into ANA1and2(split) to ADAT out 2ch @ 48khz to reciever.
Just a simple way to play at home without the amps and wiring to mess up the house.
Problem is clearly at my end, just never had any probs before using optical cables with my PC sound card or my RECIEVER..
Ive just bought a firewire cable so will try that when it gets here, in the meantime would be good to sort out this problem.
Thanks for your time
-Cam
