Home Forums Products Rackmount a question Reply To: a question
#120783
Dario
    the routing is A-B(the first one on the routing menu)with the wet/dry Level at 50% on DSP A and DSP B
    an example Preset:
    6518
    6518
    6519
    6519
    also,with the preset #218 I listen to only the Wet sound on an Amp and I listen to a complete Dry sound on the other Amp
    I have to try if It does any difference if I remove a volume pedal and if I load a THRU preset
    thanks a lot
