Home › Forums › Products › Rackmount › a question › Reply To: a question
#120785
Dario
    Hi nickrose,
    excuse me for the mistakes on the multiple replies answers 🙂
    anyway,based on your questions,I've tried everything both without the Vol.pedal and in THRU too, this is the final result:
    with a preset like the 6518(Pcm 70 Sax Hall) this is the result:
    on the Fronta Input of the Amp 1,where is connected my bass, I listen to a litlle bit higher volume signal,with a good balance between the sound of my bass and the wet sound, instead on the Amp 2,where there isn't connected anything on the Frontal Input,I listen only a full wet signal.
    with a preset like 218 (Gorgeus Delays),with the same wiring,I listen to the sound ONLY on the Amp 1,where is connected my bass,on the Amp 2 there is NO SOUND.
    the same happens if I load the preset #12 THRU,the signal becomes MONO,like the preset #218(Gorgeous Delay) and I only listen to the sound on one of the 2 Amps.
    also,with the help of my DAW,I've noticed that when I load THRU or a preset like the #218 the signal is Mono,when I load a preset like the #6518 the signal becomes Stereo,but with the problem that I listen to a different kind of sound on the 2 Amps,as I said before.
    the only way that I found to solve this problem,is to use an Y cable jack mono—dual mono,
    but I guess that this is not the best solution,
    let me know
