Home › Forums › Products › Rackmount › Expression Pedal changes programs unintentionally › Reply To: Expression Pedal changes programs unintentionally
#120794
    My guess is that you have to speak to Mr Boss.
    Assuming that most MIDI to the Eclipse is working, this would rule out any hardware issues. In which case it is unlikely the the Eclipse would mistake a CC message from your pedal as a MIDI Program Change. It is much more likely that the FC-50 is mis-programmed and is sending PC when you don't expect it to.
